Can somebody explain in more details what is exactly the memory stick jacket I've seen in P800er?
Does this means than you ccan stick another memory stick duo, extra from the other that you put in the side of the telephone?
Lets say you can have in the same time the internal memory, a 128 in the side and another 128 in the battery clip?
This is what it means?
And the memory stics it accepts must be DUO ones ore the usual ones?
Any help appreciated.
with music you never have enough space :angel:
Memory Stick jacket
as far as i'm aware it just allows you to use a normal memory stick INSTEAD of a memory stick duo.
i'm not aware that you can switch between them without some manual intervention.
normal memory sticks are cheaper tho' and some people have them already so it means they don't have to run out and but duos ...
It can only use one stick at a time 😊
For more information, there are a lot of topics aboout this alraedy, please try the searching 😊
