XML parser for use in C++ application
3 replies · 4,895 views · Started 26 May 2003
I'm developping a Symbian application in C++.
Does anyone have an idea where can I find a XML Parser ???
maybe some sort of library with APIs that can be used from my code?
thanks
You may try Expat or TinyXML parsers.
http//www.jclark.com/xml/expat.html
http//www.grinninglizard.com/tinyxml
Good luck,
Costya
Hai Associates,
I have been working on the retrieving text data from the XML string. I am using tinyxml_2_3_3 parser.I have used the following APIs to get the data
void Load()
TiXmlDocument Doc;
Doc.Parse(your_string);
RecurseTree(&Doc);
void RecurseTree(TiXmlNode *pNode)
printf("%s\n", pNode->Value());
TiXmlNode *Child = pNode->FirstChild();
for(; Child; Child = pNode->IterateChildren(Child))
RecurseTree(Child);
By using it i am able to print the contents of the string. But i should have to copy the values from pNode->Value() in to a single buffer which should be returned to calling function.
The following is my XML string.
<rx-event>
<topic>Mgmt</topic>
<subtopic>645268923afce</subtopic>
<context>PubSubComm-3</context>
<params>
<rx-status>ok</rx-status>
<column1>Hello</column1>
<column2>412</column2>
<column3>Welcome to</column3>
<column4>India</column4>
</params>
</rx-event>
I have to copy all values in to a buffer from which i should be able to retrieve
all the values one by one later. Please suggest any solution for it. I am working in C++ platform.
