hi peepz my sister got her 7650 yesterday,her firmware is 4.46. so i install
palette extender but didn't work 😮 need your opinoins and help. TIA!! 😃
help palette extender question
when you get the message that it does not work, press the left soft-key (may be called options) and continue.
That works at least for 4.39, I cannot remember hearing of its being used on 4.46
Tell us if it works
Paul
still not workimg bro :roll:
What version of pExtender are you using?
1.01 8) is there a new version?
I think you need v1.02.
[quote="j2k"]I think you need v1.02.[/quote]
This is correct. Handango has 1.02.
ok thanks j2k 😃
