hi..
just got my 3650 today, this might sound a newbie question. how can i send files directly to the mmc? i was trying to send mp3 files and had a error message, you know what i am saying, thanks for the help, appreciate it!
sending files directly to the mmc
you can use an MMC reader/writer to avoid that error message on your mp3.
Or just change the location of you Messages Inbox to be memory card.
or take PC suite and send the files to any folder you like... (which I think is the best option so far....)
[quote="TGChen"]Or just change the location of you Messages Inbox to be memory card.[/quote]
yes, but you'd still get the error message like "file not supported" if you open it at inbox. You need to install a file explorer to move the mp3's to the designated drive and folder.
