I recently bought mp3 go for my nokia 3650 and am having a few problems with it. I changed the inbox to memory card so I'd have enough memory to move it but when i go to search for it on mp3 go, I can't find it anywhere. Please help, I just bought a 256mb mmc card so I could play mp3's on it.
need help with mp3go
on what directory and what folder did you put it?
If in E (MMC), highlight the E directory in the mp3go search and just click right to expand the directory.
I do this, but when I expand it the only folders that are there are: 101. Documents, IMages, mp3(not expandable at the moment), Others, playlist,Sounds and Videos.Where should it be normally?
if you place your mp3's in the mp3 folder, they should be there.
But where is that? all ihave is the inbox, outbox, drafts, reports,my folders and sent. Where is the mp3 folder?
How did you transfer your mp3 to your phone??? Bluetooth or IR? if yes, the mp3 goes to your inbox. The file cannot be open there coz the phone doesn't recognize the format. You may need a file explorer (like windows explorer) to move the mp3 file to the designated folder.
If you used MMC reader/writer, you may put the mp3 song in drive E and make your new folder for example, mp3. It should be there.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=15611&highlight=mp3go+headset its discussed before search next time
yeah, just i thing. I posted this on may 22nd, the topic you posted started on the 2nd of august.So unless i can see into the future, kinda hard for me to search for it isn't it?
well did that solve it?
For one thing, I dont know where or how u sent it. If you sent it directly to your mp3 folder then you should search it with mp3go.
Did you look for them through mp3 go or did you just check your messaging section?
You need to go to the playlist option in mp3go and press the '+' button or press 'select>manage playlist>add song' then when you come to the right directory press the trigger and you'll see the list of mp3s you have in that folder. Then tick (or cross) the mp3s you want to add then choose 'select' (or option, cant remember) and select add song.
If u want downlord mp3 on ur 3650,7650,7250
What? 😮
If you wan't to send files to a specific folder in your phone from your PC you can use PC FileManager from www.epocware.com
hey sco2001
read this topic
thanks. I found out the problem quite quickly though, about a few minutes after the original post. I was sending other file types, not mp3's!
hey smashpOp you send the same topic as i send
