Store Contacts and Calendar in MMC
4 replies · 1,783 views · Started 22 May 2003
How two store these two (Personal) files on the memory card ?
Storing them at the Device memory can make you lose precious memory bytes. (which is used by the main memory to run apps, right?)
Try moving both of them to the d:\ under the exact same map.
The files will report in use but you can get past that by starting the backup from filemanager (this closes all apps running)
I think you can just create a new calendar on d: and copy the old one over it.
I don't know if the contacts will run from d:, but it's worth a shot.
It does work with contacts but if your phone resets, you have to go into the contacts and open the memory card contacts up again. If you dont, the phone will not recognise any numbers. Pain when someone rings you.
