3650 as a Modem
5 replies · 1,566 views · Started 22 May 2003
Now I've got PC suite working via Bluetooth on my work laptop (Win2k), I need to be able to operate in "Road Warrior" style using the phone as modem.
I've downloaded the 3650 Modem setup from Nokia to ensure that I have the latest version. When I try to install, it gets to a screen asking if I want to install the modem as Blutooth or IRDA - however the Bluetooth option is greyed out leaving me only IRDA.
This whole Bluetooth malarkey is getting on my t***s
Any thoughts/suggestions.
I've never used the nokia modem drivers, when I eventualy got my bluetooth working I found I now had a default blutooth modem device already available in my list of available modems?
Have you tried lloking at you list of modems and see if anything has 'appeared'
Best
Will
I have a similar problem. I can see my Bluetooth modem, but cannot make any connection to the internet using it!!! I wonder if it has something to do with that "modem" option in "connectivity"... it only has a "connect by infra-red" option....
I WANT MY BLUETOOTH MODEM!!!!!!
Did you guys get this sorted out? I have the very same problem - the bluetooth option is greyed out even though I already have an FTP connection open to the phone and my Infrared monitor closed. :x
Open bluetooth neibourhood, open your phone, double click on 'dial up networking' and it'll make the connection to your phone.
Be sure there are no other bluetooth connections open.
The phone number you enter is: *99#
enter you gprs user/pass and away you go.
Yes, and dont try to install that nokia modem software. It is not needed (used only with IRDA).
