Anyone having problems like mine? The connection between the two are getting worse as time goes by, it used to connect very well, then sometimes I see the thing connecting and connecting, now, I often see it connecting without any connection established.. Have to retry and retry.. Next, I bet I won't be able to connect at all. :cry:
USB Connection Weirder and Weirder..
This happens when you keep pulling it off and on the cradle. I have experienced less of these though with the new pc suite 1.5. Take note, less of these but they are still there 😞
What I usually do to solve this is pull out my phone, got to mrouter, uncheck the port which is trying to connect then check it again, then put my phone back on the cradle, works everytime 😊
Neat tip.
Will try that over the weekend 😮
I keep using that though, just that the frequency needed to use that has increased and that worrys me. 😞 Will I need to change the phone or docking station if things get worse?
