I've put all files into the folders of my SDK, but no OPL-Icon is on my Emulator ! What is wrong ?
😮ops:
Please help me !
😮ops:
Please help me !
After installing the Series 60 OPL developers package over a Series 60 PC emulator you won't see a OPL symbol. In theory you only can run OPO files build with an 9210 (real devcice or PC emulator) or opltran and copied to the Series 60 emulator by starting them using a file manager. I tried it with a WINS version of FExplorer (www.gosymbian.com) but only saw a short poping up OPL window 😞
I reported the bug at sourceforge.net and I'm shure there will be a solution...
Actually I'm using this solution: My 3650 is connected via bluetooth to the PC. I use a PC based 9210 Emulator with installed OPL developers package and copy the translated OPO files with Nokia's PC Suite on the 3650, where they are run using FExplorer. Using Remote S60 (http://www.handango.com/PlatformProductDetail.jsp?productId=56041) you can run the OPO files on the 3650 without touching the 3650 😃
HTH Martin
