is their any other code except *#7370# to reset 7650
5 replies · 8,294 views · Started 23 May 2003
hi! everyone
can anyone tell me that is their any other code except *#7370# to reset 7650, because i dont wanna use this code, it had damaged my software once..... :roll:
That's the only code for resetting. Or you can bring your phone to your nearest Nokia Care Centre to let it done.
It resets everything to the factory settings (clears all settings, all data, all installed programs, everything).
*#7780# is the only documented "restore factory settings" code. It's the same function that is in Settings application.
*#7370# is undocumented device formatting code. It's not correct to call it "restore factory settings" because it does much more than just restore the settings.
