Anyone know where I can find operator logos?
14 replies · 2,302 views · Started 25 May 2003
Just as the topic says. I need an operator logo since i accidentally delted mine. Anyone got a site or soem they would like to share?
there's a topic concerning those, here in AAS.... do a search...
you can find some colored ones here: http://nokiazone1.no.sapo.pt/logos.htm
Use File Exlplorer,FOR EXAMPLE i use FEexplorer.YOU should to folowing:1)open exlorer2)find the logo file,which you have loaded to phone3)select the file and click SET AS OPERATOR LOGO.
after i change the operator logo.. is there anyway that i can change it back to the original one? the one with my service provider name
Originally, c:\system\Apps\phone\oplogo directory did not exist.
Then, FExplorer to set custom operator logo. The file was placed by FExplorer in oplogo directory. Custom operator logo appears OK.
Next, I deleted custom operator logo from oplogo directory.
The original operator logo re-appears!
I would like to backup the original logo. (AT&T Wireless logo/Nokia 3650 USA)
How can I find the original operator logo? It does not exist in c:\system\Apps\phone\oplogo!!!
thanks, energy
yes, I thought I would do that... but it is not so easy (for me)...
Please see this thread:
FExplorer 1.1: How to capture screenshots?
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=14497
thank you
Are you keeping the ABC (pencil) button down while you are pressing 0?
If FExplorer ain't working (works fine for me), try: http://www.symbianware.com/product.php?id=screentaker60&pl=n3650
OOOOOOhhhhhh, so "ABC" = the pencil button!!!!!!!!!!!!
That was real clear... NOT!
Works great.
Thanks, energy!!!
