Help help i cannot install my nokia modem 7650 bluetooth
4 replies · 4,351 views · Started 25 May 2003
hallooo everybody
i have a problem, i can't install my nokia modem 7650 via BT. when i tried to install, i can't install via Bt only can via Infrared, i can't chose via bluetooth,
i already install my bluetooth software, there have modem bluetooth, com port, fax, dan file transfer,
i'm using Billton Bluetooth that 100 meters range..
can any one can helpppp mee ,plzzzz
thhxxxxxxx
I had the same problem and consulted Club Nokia who gave me an answer that was more confusing than the question !!! :roll:
Anyway, u don't need 2 install Nokia's modem on 2 ur PC 2 use ur 7650 as ur connection 2 the net. Simply use the Bluetooth DUN connection that should've been installed when u set it up on ur PC. It works exactly the same. If it didn't install one, simply make a copy of ur existing connection settings and change the modem in the list 2 ur Bluetooth DUN.
Hope this helps,
Rob.
Yeah, the same happened to me as well. That option is greyed out for me. I tried so many times thinking that something was missing. But the bottom line is that you really don't need to install modem options for Nokia really.
helloo its me again,,
i'm alerady install all software bluetooth modem: com port modem, fax modem,bluetooth modem,
if i want sharing GPRS from nokia 7650 with connection should i use ?, and i using xp prof system in my PC , to use setting internet connection just use like manual or what ??? :cry:
thxx for the advice
I connected via blue tooth modem but the page will not display... in the connection settings i have to change the server to Unix NOT PPP...i need some help to get this to work...
