i know its all said before but minor probs with pc suite/bt
0 replies · 2,351 views · Started 25 May 2003
i know its all been said before and loads of people have had all sorts of probs with pc suite and bluetooth and xp and bla bla bla
i wanna know if any one else gets the same probs as me cos ive read up and havent noticed any one else. These probs arent to serious and i can use pc suite but it can be annoying these are my probs
When i first installed pc suite it works fine for a while then after a while when i start my comp up it comes up with something about server busy select switch to to activate the program or something like that so i thought what i would do is take the nokia detect and the other icon out of the startup folder to stop mruoter and the other one starting up so then the message stoped but now i have to start pcsuite and then connect through mrouter as it doesnt automatically start at the beginning of starting computer. Also another small prob is when im connected to mrouter or used pc suite i cant use my right mouse button options in the system tray over the bt icon so i cant stop the blutooth device so when i shut my comp down it comes up ending program and it doesnt so i have to end now.
As i said these are only small probs but annoying ones i havent managed yet to solve has anyone else experiened these probs and what can i do to run blutooth pc suite and all that in a more stable mode.
thank u
win xp
bt009s poke 2 adapter
bluetooth driver 1.3.2.7
pc suite 1.2.0
