hi
I use this settings for encoding my videos
and the sound and framerate seem to be fine but the video quality im not happy with....is this setting fine??
or is there any setting which can make the video quality alittle better
and id appriciate a picture of the settings you guys use 😮ops:
thanks
Helix Producer help required!!
try putting the bit rate to 90.
wont that make the video run slower??:P
or will it work fine?
can someone tell me what the 2-pass video encoding do??:P
I do have a Nokia-3650 Version 2.50 since last February 2003. Meanwhile I had also down loaded Helix Producer 9 - Basic Version, which was intended to encode my non-commercial video lead of Technical Manual guidance from the original Mpeg, DAT to be RM ( real Media ) formats to enable my technician and my colleagues whom own Nokia-3650 and 7650 could play back those on their RealOne Player which is a standard supplied on Nokia-3650 on their trips to several locations of remote project areas. However since the Helix Producer 9 Basic Version has only limited capabilities ie : unable to have the option of Video codecs ie. the former RealVideo 8 codec ( merely able to encode based on the new RealVideo 9 codec, whereas on the other hand the current standard RealOne Player of Nokia-3650 can only play back based on RealVideo 8 Codec ) , unable to resize to lower 160 X 120, etc etc. So, I am now eagerly to find someone whom have the HELIX PRODUCER 9 - PLUS version. Since my intension is obviously for Non Commercial purposes, so this is legal to ask helps from you all. Would you kindly contact me at [email protected]. Is there someone to hel me ??
j2k edit: no warez on All About Symbian
Hi...
did you manage to create any video file with helix producer basic that is played succesfully in the real phone..?
could you give any directions in how to do that...?
(an example-with the parameters..)
Thanks in adavnce!!
Manos Moschous
[email protected]
Arnold,
Do you read any other NOKIA3650 FORUMS? It's amazing what you can find if you SEARCH hard enough! HELIX is a CRACKing program! 😉
