How to delete the midi files in the phone
5 replies · 5,062 views · Started 09 July 2002
Hi guy, I had put some midi files into the 7650, but I dunno how to delete them. Any expert can teach me how to do that? Thanks!
How do you put them there?
Normally you can delete those from voice recorder.
Yeah, how do you put the MIDI files into 7650? I was reading the PCSuite guide but I saw only "transfer images, documents, settings...", not ringing tones or any files. And the folder to store ringing tones into 7650 is a system hidden folder, isn´t it? Then how can you use PCSuite to transfer MIDI files from PC to 7650? :-?
Hi guys where can I get good midi file and which is the best wayy t install them.
cheers,
Mustu 😃 😃 😃 😃 😃 😃 😃
How to put the midi file into 7650:
1) Download your favour midi file from internet
2) Using a IR device to connect your phone to the computer
3) If your IR device is setup properly, then you can right click the midi file, select "send to XXX device through IR"
4) After a while, 7650 will show up received a message, then select save it.
5) From your phone, go to Profiles, select one of them, choose Personalise, Ringing Tone, then you will find your midi file here.
That's all, but I dunno how to delete it... :roll:
:P Hey guy, is me again, I had read the old post and find the answer now! Just go to the Voice Recorder application to delete the midi files!
Cheers!
