Doom game sound problem !!!?
2 replies · 3,356 views · Started 26 May 2003
hi.
I installed Doom game in my nokia 7650, it started well, but any way to have sound !
is there a method to install it, or a specific download version of Doom game.
As i know 5 file with SIS extension had to install them.
thank in advance for response
ahah! yes you need to also download a game from wildpalm
it has the neccessary sound driver that will enable you to hear doom.
so... install doom sis files, then install a wildpalm game, which should install an additional sis file called WildPalm Sound Server. ( i recommend a game called stackup, as it is relatively small)
the only problem i can see with this, is that my trial period for stackup will expire in about 3 days, and i am unsure if i will be able to keep the sound driver when the trial expires, i think it will be automatically removed when stackup dies.
maybe someone out there knows how i can get into the belly of my 7650 to pull out the driver file before stackup dies...?
Turtle.
the sound is working finally ..... thanks for your help Turtle .
