I just bought my 3650 2 days ago and aside from the camera it won't work in the house-no in/outbound calls nothing. Please tell me this isn't a common con that doesn't have a solution. I can not be limited to only using a cell phone when I'm away from home. Please tell me there's something I can do before I'm faced with having to ...god forbid, take it back!
Indoor signal issues with my 3650
Surely there is something wrong, either the signal is extremely low at the area or your walls are built of steel 😃 or perhaps you live underground 😃
Seriously, of course a mobile phone (including 3650) should operate indoors as well. You should test your phone in other locations as well, if it seems to be problem everywhere, have you phone replaced, it is not normal. If you have had older phones and they operated correctly, I'd say that so should 3650.
I find the 3650 reception great! I agree with all cambba said... maybe it's where you live.
