Hello everybody, I just wanna contribute my two cents for those who have the same problem I did have until yesterday... Here's my story first and at the end of the post my how-to solution!
I had a Palm OS Visor Handspring PDA and bought a P800. I had read on this forum that to migrate addresses from Palm to P800 I had to go through Outlook, as opposed to the Palm Desktop software I had always been using. That's where the nightmare started (it's Microsoft, so there's not to be surprised that it turned into a microsoft-mare!).
The theory says to uninstall Palm Desktop, download the latest version from the website (in my case handspring.com, in a Palm user's case palm.com), reinstall it and choose "sync with third party PIM".
I heard that actual Palm users (as opposed to Handspring users) are offered the actual "sync with Outlook" option during installation, but on the Handspring version of Palm Desktop it just says "sync with third party PIM".
When you are done you are supposed to install the bundled Outlook Conduit software (on PC's just click on Start>Programs>Handspring and it's there)...
I had version 3.1.2 of that software (which is made by chapura.com) and which is also called Pocket Mirror and the latest version at the time of writing is 3.1.3.
At this point, aware of the fact that syncing with MS Outlook will create occasional duplicate entries or merged contacts fields and will not carry on the categories of the contacts, I tried everything to have my Palm OS device speak to Outlook but it just wouldn't happen. When I didn't know what to do I decided to try with version 3.1.3 and dowloadedn the free upgrade from chapura.com. This 5Mb download wouldn't even install and it kept telling me "you have to have Outlook Express installed on your computer" which of course I had...
I am not gonna tell you all the other errors I kept getting during my tests (such as mapi32.dll libraries etc etc) but I will tell you that if you wanna try yourself make sure to use the chapura.com's troubleshooting FAQs and knowledge base because they are really well done and complete and they cover every possible problem I did encounter (except for that "you have to have Outlook Express installed" error which I did report to them so maybe when you will be using their site they'll have that covered too).
Anyway, long story short, I gave up on Outlook. I had never used that software anyway, 'cause it sucks compared to Qualcomm Eudora, which is fantastic!
By the way I did try this both on Win XP Pro with Outlook Express 6 and on Windows 2000 with Outlook 5. No luck.
So I found this solution:
- Sync your Palm OS device with Palm Desktop (meaning that if you first tried all of the above you will have to reinstall Palm Desktop again).
- Go to the Address Book and click on the first contact then press and hold the Shift key and while you hold it click all the contacts that you want to migrate. If there are many of them you can scroll them down (while holding shift) by pressing the arrow down key or the Pag Down key).
- When all the contacts you want to export are selected and highlighted from the FILE menu choose "Export vCard...". Give it a name and a location.
- At this point I simply beamed (via Infrared) this file to my P800. You can also send it via Blootooth or email.
- When the P800 receives it you can simply click on VIEW and it will tell you that the file contains Contacts and will ask you if you want to add them to your CONTACTS, you say yes and the trick is done.
WARNING: I had lots of contacts (over 500) and when I first tried to beam them all the P800 couldn't take it, don't know why... I guess not enough memory or processor speed. The solution to this is to export the contacts in batches of 50-100 each. That worked fine for me.
The advantages of this method are:
- you skip the damn Microsucks Outlook Shitpress
- it is WAY faster than Outlook (I have read somewhere that it can take many many minutes, even up to half an hour, to sync 500 contacts with Outlook and a P800 whereas beaming and recognizing these vCard .vcf files takes seconds)
- no hassles such as re-installing Palm Desktop software or other softwares and things like that, ie no new downloads either
- it does NOT create duplicate entries
- it does correctly handle entries with two Work phone numbers or two home phone numbers (whereas Outlook would merge those fields into one field and you would then have to re-separated them)
- you don't have problems with brackets that I read somewhere Outlook does add to numbers
The disadvantages of this method are:
- the categories are still not carried on (but that wouldn't improve on Outlook)
- it obviously only works for contacts and won't do for agendas/date books
This is my contribution to this forum.
I don't know if I am the only guy who had no luck with Outlook but I am a pretty experienced computer user and I must say I tried everything!!!
This method worked for me and I am glad I skipped Outlook all together!
I have all my contacts now!
