9210 like remote control for tv?
8 replies · 3,185 views · Started 26 May 2003
wat u nid dat for anyway? i dnt think that sch an expensive devise will jst be used as a remote control! I mean the tech is definitely possible, but i personally wudnt care if it does already! It will jst add up to the normal ware & tare of the phone!
thats not really a helpful answer is it!! :roll: Anyway, hi alexi, ive also seen the same thing somewhere but like you i also cant find the site again. However i will have a good look for you to see if I can find anything. Im sure it possible as ive had a 9110i controlling one of those furby things before!! LOL!!
-Wills
Yah they have IR remote software or Nokia 7650/3650 and now also for P800. My wife uses for 7650 & its gr8 using it. I already contacted psiloc.com for nokia9210i but they say they have no plans for it.
I guess its not possible but you never know they might develop it one day
Cheers !!
If you want the remoute control
go to my subject (remoute control for 9210 beleve me)
[quote="Anonymous"]If you want the remoute control
go to my subject (remoute control for 9210 beleve me)[/quote]
I tried it but had some problems. Sent this note to [email protected]:
"Dear Sirs,
I downloaded the trial version of your program yesterday and installed it on a 9210i. I have 2 TV's; your IR device seems to work fine for the Phillips. However, for the Sony TV, I found a few problems:
1) When I selected device "SonyTV", I was initialy able to turn the TV on the 1st time by selecting channel 1 on the 9210.
2) When I tried to select device "SonyAlt TV", I got a message in green text "Layer for selected device not found".
3) When I tried to select device "SonyAlt2 TV", the channel changed on the 1st attempt. Thereafter I got no response to any key presses.
Can you help with this?
Another question....does the commercial version come with a guide to the buttons, etc?
If you can fix it, I will purchase your program.
Kind regards"
I never got a response, so unloaded it and that was that. 😞 😞
[quote="wills54321"]thats not really a helpful answer is it!! :roll: Anyway, hi alexi, ive also seen the same thing somewhere but like you i also cant find the site again. However i will have a good look for you to see if I can find anything. Im sure it possible as ive had a 9110i controlling one of those furby things before!! LOL!!
-Wills[/quote]
Nope it wasnt! :evil:
jst tryn to stress out my point that sumthings are beter left the way they wer. But thanks for reminding me thou, i guess i got of on the wrong side of the bed that day. I'll try to kip an open mind next tym! 😉
