I was just wondering, can two phones connect via bluetooth and transfer files.. i was just thinking about it and dont recall seeing anything like that or hearing about if its possible or not? Can anyone help me out here..? :-?
Capabilities of blue tooth on the 3650...
Well yes. A friend of mine has the P800 and him and me can transfer files. We had some problems to begin with, with his phone accepting mine, but we got there somehow *g*
so the answer is yes to your question Frenchie746 😉
yes... you can transfer files and pictures to phones that has bluetooth.
well i store my files in the my folders of Messages so how can i transfer it out of thier? and where do u guys store urs?
I created a folder in my MMC card.
Saving them in "my folders" isn't the best move... you can't even access them using PC Suite...
I just use File Explorer to send my files... coz in messages, some sort of messages cannot be forwarded or something.
Do any of you have the bluetooth headset for the Nokia 3650? Is it worth getting? What is the audio quality like? Is it comfortable? I have seen the pciture but cannot get a good feel for whether it looks good or bad when you are wearing on/over your ear. Please share your thoughts whether it is a good add on
iv seen my mates one he uses an SE one on a nokia 8910... works fine i asked why he bought a SE one instead of a nokia and my other mate also said tht nokia ones arnt as comfy or good as SE one and thts wot he said to
Does this mean I could pair an Ericsson Bluetooth handsfree HBH-20 that was previously used for a Sony Ericsso with my 3650?
yeah mate I reckon you can use an HBH 20. I have paired a 3650 with an HBH 15 and it worked fine.
But in response to an earlier post by - the HDW2 is pretty bad. sound crackles battery life is pretty bad. You are better off with either the SE HBH 30 or 60. Both have good sound quality and battery life. 😊
