Anybody know if chinese text support is available on the 7650?if yes,where can i download or buy the software?thanks!
Chinese Text Support?
yes, but the only easy way is to get the software built in, it's possible to get some software whch will allow you to do it which you get can off ebay.
My friend need it too!! What is the name of it?
