Absolute novice just bought first 9210
10 replies · 2,794 views · Started 27 May 2003
Just bought my first 9210 (pre owned) amazed at what it will do already, and it is smaller (well nearly ) than the Revo. I have been using Ericson T39 and Revo Plus and Psion S5 for while.
All you well versed persons will think it daft but two 'problems'
1) I can't seem to be able to load 9210 PC software on my desktop, requires I delete Pswin, that I still want to use as S5 and GPs are used regularly. Can I use 9210 PC suite to back up Revo and S5. 😞
2) Is there any easy way of transferring my contacts, address book and diary from either Revo or S5 to 9210? 😞
Read some of the forum pages, really good stuff, whoever organised it , and contributors well done.
My days should be easier when I get it all together 😃
tinhat
[quote="Tinhat"]😃
tinhat[/quote]
Then i suggest that u use a double OS on your PC! For ex. if ur using Win 98 now, why not upgrade to a WIN XP and make it your secondary operating system. all you have to do now is to choose the desired OS everytym you boot up for either techtoy you wud like to link up!
As for the contacts i think either LOTUS or Outlook will do the job for you! jst try to find your way around and will surely work out!
Hope i helped!
Unfortunately 2 OSs is the way to go, for some reason dispite it being an updated PsiWin the Nokia suite won't detect Psions and won't work with PsiWin. Also I'd avoid WinXP for a second OS, use Win95 as it will require the smallest amount of space and boot faster.
[quote="SwitchBlade"]Unfortunately 2 OSs is the way to go, for some reason dispite it being an updated PsiWin the Nokia suite won't detect Psions and won't work with PsiWin. Also I'd avoid WinXP for a second OS, use Win95 as it will require the smallest amount of space and boot faster.[/quote]
Well i agree, but for me its more stable and hassle free using XP. I guess it all depends on wat kind of system u have. UPGRADE! 😉
[quote="The Godfather"]Better xp...even if some times it creates some crashes... :roll:[/quote]
It does? never happend to me... yet! hope not. 😉
So far for me the best OS ever! I mean 98 SE is great coz it suppots a lot of old programs that will no longer run on XP. But hu uses them now anyway. im sure der r only quite a few of wc u can count.
Not mch to argue, jst a thought! 😉
A piece of advice if u dnt mind.
U can surely sort things out if u try to avoid using old and dated programs that have compatibility issues running w XP. 😉
