P800er.com is selling (or will be soon) a replacement battery cover that includes a Full Blown Memory Stick reader!! I suspect from their description that it is still limited to 128MB and at $100US it seems rather expensive, not to mention makes the P800 bulkier.
Thickness : Less than 5 mm
Speed : Reads a 128mb memory stick in about 5 seconds
The jacket allows you to expand memory on P800 with Sony Memory sticks. Simply remove the battery casing to fit the Memory Stick Jacket in
Install software on the memory stick, transfer photographs, storage file and so on.
Yes yes, we all know about it. :roll:
Yes, this is indeed very old news. I believe this about the fifth time this is being placed here... :roll: :robot:
so where can we buy it? is it out?
forgot one thing ,would you then have possibility of working both sticks for 256MB
[quote="mrgadget"]forgot one thing ,would you then have possibility of working both sticks for 256MB[/quote]
No-one knows fur sure, but probably not. I heard that it can only read one stick at a time... Don't think about trying to put a big/normal 256 in it either, the p800 only supports 128 ('til now)
