I did a hard reset & now Chess is gone.....
2 replies · 2,194 views · Started 28 May 2003
I'm quite ticked off.
I had a problem with getting GPRS set up and running under Orange in the UK. One of their not so helpful support staff suggested a hard reset of the phone which cleared all the installed applications.
Whilst i can reinstall most things I don't have Chess or the Solitaire type game. Not too fussed about Solitaire but i loved Chess.
Anyone had the same problem and if so did you find a solution???
:evil: :evil: :evil:
If this question was really dumb, please don't flame the newbie.... Thanks
Thanks erikjan.
I'm not sure where my cd's gone but i know a friend i can borrow that CD from...
Cheers
:angel:
