hey y'all, I want to ask you guys about msn messenger for N3650
can you download the software/application to the phone?
I'm really inteested in this...and i don't mean using the mesenger through
mobile.msn.com.
thanx a lot!
i appreciate it 😉
mobile.msn.com.
thanx a lot!
i appreciate it 😉
Well TipicME (Can't remember the url) works with 7650. Try if it works with 3650 too.
IM+ works well too !
i have im+ and i cant connect to msn my phone says:connection to msn server failed, how does that come???:s
It's working fine for me.
It connects straight to MSN, not via a third party proxy like the others - are you using an internet connection or WAP?
i am using imode that is an gprs connection on my phone but it is not a wap connection and it doesnt wor 😞
Must be something in the I-Mode connection that is screwing it up I guess.
agilemessenger dont work well, i've just got 1 contact insted of my hole list
coojoi dont do anything
tipic works fine, i've now only the basic one but i will also try the pro version in a few days
connetion is made by GPRS
Strange 😮
I've had no problems at all with Agile Messenger but could not get TipicMe to work!
-Jim.
http://mmsmemo.blogspot.com
i think that the problem of the messengers lays in the GPRS-connection... you just got to test & see what works fine with your GPRS provider
Will there be any MSN software that works after MS locks the 3rd party clients out on October 15th? I want to use it when I get a 6600. In order to connect to the MSN messenger network after that date you need to get a licence from MS. Are there any Series 60 programs that are getting a license? I don't mind if they arn't free.
So do any of the MSN Messenger programs still work?
Is anyone working on making one work?
Hello,
I've put Agile Messenger on my phone, but after I get the settings from the orange provider (doesnt need to be changed right?) the agile messenger doesn't work, and says "Cant connect to server, please check your GPRS settings." Btw, I've read on the site that your username in the GPRS settings have to be your phone number? But I get 0628000000, and that aint right. After changing this, it still doesn't work. I've also called the phone service to help me, they said, delete your settings and ask for them again, but it still doesnt work.
Otherwise, I might be able to buy for the IM+ Messenger, but doesnt that need GPRS too? (expensive??)
Don't know anymore, please reply or send me an email plz.
Also need a good fullscreen player!
