AT Commands
5 replies · 2,541 views · Started 28 May 2003
Hi
Does anyone know the correct AT command to drive the phone into HSCD ie 28BPS V34 or even V120 not sure if that is supported.
Tony
Well, this must be done before starting the call.
Type AT+CBST=16,0,1 and <cr> for 28800 bps V34, or
Type AT+CBST=79,0,1 and <cr> for 38400 bps V110.
Of course, you must type AT&W and <cr> after the above, to write these settings to memory, and then you can start the call (ATDTxxx....).
P.S. AT+CBST=0,0,1 is the default (autobaud) setting
Thanks for that. I wish to add them in the Modem addittional commands entry do I need the <cr> or will windows assume that ? Or do I need to use an ASCII CR
Tony
No, you don't have to enter <cr>. Let Windows manage with it! 😉
If you have any further questions, I'm here!
Good luck!
hello,
is it possible (and if is,how) to send at commands from symbain app directly?i need to write app for symbian 7.0 which will call some AT commands independent from pc?
thanks
