hi guys,
I rcvd a mail from doml saying that the ms jacket is now available 4 me 2 buy....ges thats cos i pre-ordered as soon as it was out....
I already hav a 128mb duo so am wonderin that is this really worth buyin at $90? wot do u guys think?
Cud u guys list out some pros n cons....
thanx
cheers
My opinion is that if you have a 128mb duo like me, skip it, there isn't much use for now or even in the future unless you are planning to get or you have normal memory sticks already. Or you are rich.
If I didn't have duo, then I will get it for sure.
The ONLY reason I would be remotely interested in the jacket, is if it can take a 1GB memory stick pro - which it can't, unfortunately.
The 'jacket' was designed because there was such a shortage of memory stick duos, but now you can get it from www.p800er.com, so there's no need for it anymore. Also, it makes your p800 REALLY huge!!
[quote="kingrob"]😮
The 'jacket' was designed because there was such a shortage of memory stick duos, but now you can get it from www.p800er.com, so there's no need for it anymore. Also, it makes your p800 REALLY huge!![/quote]
Mine would be if we could use it at the same time as the duo. But we cant so not worth it all.. I got that email too but I skipped it..
The words "beached whale" springs to mind..
Very funny, Raven! I almost fell of my chair laughing and my work colleagues were just staring at me...
Its a waste of money imho. Just add a little bit and you can get the 128MB Duo without the added bulk 😊
