I don't know if this topic has been posted before but i want to print out a hardcopy of the contact details. Is there a procedure to that ?
Print Contacts List
Synchronize/export to PC & print from there is the only way I know (unless you have a Bluetooth or infrared capable printer you can send them to).
U mean sync it with Outlook ? I tried with Outlook Express and it says UNABLE TO FIND OUTLOOK.
[quote="aCiDByTe"]U mean sync it with Outlook ? I tried with Outlook Express and it says UNABLE TO FIND OUTLOOK.[/quote]
Have you synchronized using PC Suite? I couldn't do it without it...
[quote="aCiDByTe"]I don't know if this topic has been posted before but i want to print out a hardcopy of the contact details. Is there a procedure to that ?[/quote]
You can use export with Contacts Manager.
http://www.agora.cz/agora/agora.nsf/0/EEFD708566D50DEAC1256CEE005AAF27
