How to open *.amr?
6 replies · 3,407 views · Started 10 July 2002
Hi all, I had try the Recorder function from the phone, it will create a file with extention "***.amr" after record. So anyone know how to open this kind of file in the computer? (I means after send the sound clip file to PC, sorry for my poor English!)
Thanks for reply!
here is the link... fresh from Nokia website (they added it today)
http://www.nokia.com/phones/productsupport/7650/downloads_amr.html
😉 hope it's useful to you
p.s. the file is about 5 MB to download... and you NEED to register with the correct email address since you'll have to insert a code to install the program
[quote="Richie"]Hi all, I had try the Recorder function from the phone, it will create a file with extention "***.amr" after record. So anyone know how to open this kind of file in the computer? (I means after send the sound clip file to PC, sorry for my poor English!)
Thanks for reply![/quote]
Hi can you please see your call log and tell me if there is a difference in the time between the log and the standby screen time.Please do this by making a call and then checking the time.
Thank you,
Mustu
Thank you,
Mustu
Thank you,
Mustu
To: faquick
I had follow your word to download the decoder plugin, thanks a lot! But I had download the "Lite" version nad it doesn't require any register code!
To: Mustu
I had try 3 times and mark down the calling time, but I didn't find any problem from the log. Those marking of the time are correct. Any problem you have? Please share to us!
Richie
(from Hong Kong)
And how could you download from the Nokia 7650 to your PC any data (incl .amr files) ?
Do you need to backup all your 7650 with "PC Suite" :cry: or do you
have any other way to do it 😃 ?
Thank's
Trick Lo.
