help!!!! i can't compose messages
when i go into the composer i can only type in numbers the letters don't work
how do i switch from numbers to letters??? i want the little abc in the corner
Deactivate WildSkinz
yes. I got the same problem. Uninstall wildskins... if the problem still continues, reset your phone.
still nothing.............
all the text doesn't work....even the notes, searching contacts...
it all shows up as numbers...
any other solutions?????
Deactivate Wildskinz then uninstall it and reboot the phone.
It will work.
nO , it doesnt work with ma phone :cry:
- i have already uninstalled
- i have already reset
but it still not working ????
any ideas plz...??
:cry:
Reset = type it!: *#7370#
This is the full factory reset! All program will be lost! Recommended after it the MMC format!
Good luck 😉
I've never tried (beacuse of so many reported problems) WildSkinz, but the procedure to get it off seems to go something like this:
1. Install the bugger.
2. Reboot.
3. Enable it (I suppose it has a menu option or something for that).
4. Reboot.
5. Disable it.
6. Reboot.
7. Uninstall it.
8. Reboot.
Or simply,using a File explorer program,navigate to C:/system/system.ini and delete that lil baby..=D
oh thats me ^^^
or better yet, throw that hunk of plastic they call phone in the disposable sink tingie and turn it on!! See the bits fly!! 😃
well, umm.....Yeah, you should do a factory reset 😃
