Can I use this on my MMC for my 3650? And if so, how much more room do I create? And does it slow down the running speed of the MMC if compressed? Thanks!
Can I benefit from these 'space doubler' programs?
I dont recommend you to use Space Doubler,it slows down the phone.
[quote="jimmy-floyd"]I dont recommend you to use Space Doubler,it slows down the phone.[/quote]
No it doesn't slow the phone. But it slow's program starting as it's zips the programs when you don't use'em and when you start using them it unzip's them so it takes a bit more time to start them.
Of course it's better to get bigger MMC.
I uninstalled Space doubler,coz to open some packed applications by SD takes a lot of time.
[quote="jimmy-floyd"]I uninstalled Space doubler,coz to open some packed applications by SD takes a lot of time.[/quote]
SD? You can't use SD on your N3650.
And that's because it's bit slower to read from MMC. I only use it for programs that i don't use so much... But when i get 128MB MMC, i'm gonna uninstall it too.
Why not..I used SD on my 3650,i havent got MMC,but i will buy it soon.
[quote="jimmy-floyd"]Why not..I used SD on my 3650,i havent got MMC,but i will buy it soon.[/quote]
Oh, sorry, just figured out what did you mean by SD.
I was talking about the other memory card type... Sorry, my bad.
I meaned SD-Space Doubler.
[quote="jimmy-floyd"]I meaned SD-Space Doubler.[/quote]
Yea, i know... It was my bad.
No problems.
