Recorded a video on my 7650... how can I get it on my pc ?[/code]
Video To PC
Also note ive done a search and used a file manager program to try and send it to the pc and i just get 'sending failed' error.
Can you send other types of files to your PC? If you can't,then search the forum for the "sending failed" problem.
its ok I sorted it.
The accept other fix solved it.
