sLauncher Problem?
6 replies · 1,920 views · Started 01 June 2003
Today when I turned on my mobile the slauncher dident start automatically (happens to me sometimes)....but that had happened to me sometimes before but worked next time i restarted it but now whenever i restart or turn on my phone the slauncher doesnt start automatically i have to turn it on by pressing it and then setting it ON then it works but after a restart it turns off again??
why is this happening?anyone got any idea?
What version do you have installed? I have read that the older versions had this problem at times and it was fixed I think in the newer ones.
We are now up to version 1.02 which is the best by far. Version 1 was ok, V1.01 had a major bug in that it killed the menu screen at times and the user had to reboot inorder to get it working again.
Try the newer version, also make sure you have the latest Skin Editor to go with it as again older and newer apps don't appear to mix as well as they should.
Ian
Maybe some files were damaged. Try to reinstall SmartLauncher. If it doesn't
help turn to the technical support at the email address "SymbianWare, tech"
<[email protected]>.
One thing thats just popped into my head, especially as this is the 3650 forum did you install the app on the phone or MMC card?
Reading through here some programs are very funny about being installed onto the MMC and not the phones internal memory.
I'm unlucky enough not to have these problems as I'm a 7650 user and don't have any memory :cry:
Also you aren't perhaps using it with Stacker or Space Doubler compressing it? Just ideas maybe.
Ian
