i did a seach but nothing came up. i guess less than 1 Megapixel
what Megapixel are the 3650
Quite a lot less than one megapixel I think. To be honest I don't think it's even been quoted, I may be wrong though.
You need to work on the assumption of a resolution of 640x480 as this is the maximum picture size available for these nokias.
Again a 3rd party app like Photographer makes better use of the available quality by not reducing the picture so much to save space. If you haven't got this app I can whole heartidly suggest you buy it, for the price you will not be disappointed in the quality and the 3650's camera software is marginally better out the box than a 7650 which I have so it can only be improved.
So far I've only heard of one 1megapixel camera phone and thats a Casio available only in Hong Kong at present, they'll come soon enough but not here yet.
Ian
0.3 Mega Pixel,correct me if i'm wrong.
Correct Ghostdog. That is also what I have read in the specs 😊
thinks guys
i was thinking of buying Photographer 2.2 but not sure the price or if it was worth it. sounds like it.
the one i found was from open bit. i didn't see a price on the site.
[quote="GhostDog"]0.3 Mega Pixel,correct me if i'm wrong.[/quote]
Yes, you are right. It's only VGA camera.
(640*480)/1000000=0.3072 Mp, to be exact.
Thanks,i also want to say that Photographer is best camera soft.
Afcourze its not major quality, but good enough for fast picturing a nice lady's ass 😃
Ya,man 😊 You are right.
Jimmy-Floyd, you changed your avatar picuter? What's up? Did you take it with the 3650 you are holding? (i.e. using a mirror?).What camera software? Photographer 2.2?
hehehe He would have to use at least 2 mirrors (probably 3) if he wanted to do that... LOL
...and then he would have to use a powerfull zoom!! 😃 😃 needless to say the quality would all be gone...
