Bluetooth internet connection
1 replies · 2,260 views · Started 02 June 2003
Back to to the same old connection via bluetooth gateway thing.
I am trying to connect via bluetooth through a pc on a lan with a dedicated connection through a firewall and router. What settings should be used in the dial-up settings on the P800 to make this work with Opera.
Whenever I try connect. It comes up with an "Information Unknown error box"
any ideas anybody
No special settings required. Just make sure that your SE phone connection link shows that your phone is connected to your PC (via DSS, IR or BT). once it's connected, your phone will automatically be on-line via your LAN connection
