Does anyone know the pinout for the bottom connector?
SE won't reveal it. Im planning to connect the P800 to my car radio and listening to MP3 without having to have an extra 2.5 mm plug.
Bottom connector for MP3
I dont think you can liste to MP3 by connecting a headset to the bottom. Its just for handsfree calls.
i bought a spare headphone set for 2nd car, it was just an Ericsson T? connection(i am unsure of model), but it def works...
maybe you can run a connector from that into your audio in jack?
best of luck...
Isn't the bottom connector just mono anyway?
the bottom connector is not mono, but i could not hear MP3 either from it. I would suggest connection to the headset pin of the phone instead
I cannot confirm it but I am almost certain the bottom connector is mono, as it is used for all previous phones many years back as handsfree connector.
If you connect a headset to the bottom connector and play an mp3 it just comes out of the internal speaker, you would have to connect thru the headset jack on the side with an adaptor.
[quote="sidneylopsides"]If you connect a headset to the bottom connector and play an mp3 it just comes out of the internal speaker, you would have to connect thru the headset jack on the side with an adaptor.[/quote]
Exactly! 😊
