listen guys i need help with prince of persia
i installed the game and then when i try to run it just sticks on the
gameloft logo...doesn't load the game.
I tried to install on both MMC and the phone memory, same result.
Any comments/help would be great.....
thanx
sometimes i've this prob, too!
Try to "reboot" your phone, and play it immediately 😊
Ciao!
prince of persia is old now!
You might want to try zelda using the gameboy emulator (goboy) its great!!
Where do you get the Roms from???
You can also download JAVA midlet of Prince of Persia.
[quote="jimmy-floyd"]You can also download JAVA midlet of Prince of Persia.[/quote]The Series 60 version *IS* a Java midlet, already.
I would post links to roms but they'll just get deleted!
Check www.wildpalm.co.uk! They have links on the goboy page!!
Thanks,but all links would be deleted.
