Two questions
1 replies · 1,280 views · Started 03 June 2003
1. Have anybody notice this problem with their Nokia 3650. When you connect the HBH-60 (SE BT headset) to the phone, it sometimes get disconnected after about 10 min, but if you BEFORE you connect the headset to your phone, restarts the phone and the connects, it works joust fine. I have v2.5 on my phone, doe�s somebody know if the BT problem in fixed in any newer version, or have somebody else experienced this problem.
2. Have anybody tried to sync a groupwise calendar with syncML (or any other sync program), or is it even possible to sync groupwise with 3650? Or do I have to install an Exchange server with is in sync with the groupwise server?
Thanks!
Br // Fredrik
