GOOD NEWS! We now have a user friendly GUI frontend for the command-line based EYECON program. It also allows simplier and more reliable installation. The good man behind this fabulous program is j2k. THANK YOU J! YOU ARE THE MAN!
http://www.eyemail.com.cn/Chi/camcoder/EYECON.zip?providerID=1&protocolID=1
This is great news! I'm really used to all the prompts,except command prompt 😉
[quote="dfdzgz"]GOOD NEWS! We now have a user friendly GUI frontend for the command-line based EYECON program. It also allows simplier and more reliable installation. The good man behind this fabulous program is j2k. THANK YOU J! YOU ARE THE MAN!
http://www.eyemail.com.cn/Chi/camcoder/EYECON.zip?providerID=1&protocolID=1[/quote]
No problem. 😊 Please forward any problems encountered with the GUI to me via PM or e-mail.
Cheers
i installed this converter and got following error message: Component Comdlg32.ocx or one of its dependencies not correctly registred: a file is missing or invaled.
can someone help me how to install it correctly?
Please see the thread in the Nokia 3650 forum for information about fixing this problem.
Cheers
i didnt find the solution for my problem on the 3650 forum. can anyone help please?
[quote="AndreasLLL"]i didnt find the solution for my problem on the 3650 forum. can anyone help please?[/quote]
It is in the 3650 forum - you need to copy the comdlg32.ocx file into your windows system folder then regsvr32 it
Heres the thread..
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=13380&start=15
Best
Will.
