New Symbianware titles
12 replies · 75 views · Started 04 June 2003
I quite fancy reviewing SmartClock and SmartProfiles....
unless anyone else wants to jump in, I'll go ahead over the next few weeks.
Steve
Start Smartprofiles if you don't mind?
Don't known about SmartClock just yet, but I would be interested in doing this maybe with a small clock 6 compare.
I'll let you know as fast as possible?
I should say that Symbianware are quite happy to give AAS reviewers a reg code for any program of theirs.
I'm not sure from Steve's post whether he's spoken to them or not. If not let me know and I'll get it sorted. There wouldn't be a problem if you both want to look at SmartProfiles. I think Symbinaware need IMEI's so I would need those if you want be to sort it.
Yes, they need IMEI, yes, I'm already talking to them, and yes, I'll do the SmartProfiles review and Dazler can do the SmartClock one.
OK, all?
Steve
I'm not about to steal your reg code slitch.
So don't worry about me if you really want it 😉
Otherwise throw it over ... 😉
No, no, I don't fancy SmartClock at all any more... Not my cup of tea after all. Do you still want a crack at it?
Steve
I still have some reviews for their apps.
Daz, shall I send them to you once again?
I guess is long time since then, and Boris will be not pleased if I wil not publish them... 😃
