SYSTEM ERROR PLEASE HELP
4 replies · 1,286 views · Started 04 June 2003
HI
I have a very bad problem
I instaled SmartLauncher v1.02 (cracked) and after i restarted my phone i can't aces the menu, the contacts i can't acces anything.Iget an error SYSTEM ERROS.
If i remve the MMC and start the phone it works.But when i put it in again it doesnt work.
PLEASE help what should i do.
I did also a hard rester with *#7370# but also same problem.
I insatled SmartLauncher on MMC
PLEASE PLEASE HELP
Had the same problem once...you have to format your memory card
turn your phone off and then hold the abc button(the one with the pencil made on it)not 2
hold that then turn your phone on and keep on holding for 20 seconds once your phone is on properly then go to the menue and format the mmc
GREAT.It worked.
Thanks a lot dude.You really rock
What else you know?(like secret codes,hacks etc.)
PS:What country are u from cause your nick(name) is pretty familiar in my contry (Romania)
[quote="Anonymous"]HI
PLEASE PLEASE HELP[/quote]
One could argue that it was your own fault for installing warez.
Concerning the problem of no more letters, delete c:\system\system.ini. It
seems to work all the time with a program like fexpllorer. That way you don't have to reformat the card
