I do have a Nokia-3650 Version 2.50 since last February 2003. Meanwhile I had also down loaded Helix Producer 9 - Basic Version, which was intended to encode my non-commercial video lead of Technical Manual guidance from the original Mpeg, DAT to be RM ( real Media ) formats to enable my technician and my colleagues whom own Nokia-3650 and 7650 could play back those on their RealOne Player which is a standard supplied on Nokia-3650 on their trips to several locations of remote project areas. However since the Helix Producer 9 Basic Version has only limited capabilities ie : unable to have the option of Video codecs ie. the former RealVideo 8 codec ( merely able to encode based on the new RealVideo 9 codec, whereas on the other hand the current standard RealOne Player of Nokia-3650 can only play back based on RealVideo 8 Codec ) , unable to resize to lower 160 X 120, etc etc. So, I am now eagerly to find someone whom have the HELIX PRODUCER 9 - PLUS version. Since my intension is obviously for Non Commercial purposes, so this is legal to ask helps from you all. Would you kindly contact me at [email protected]. Is there someone to help?
-GhostDog edit-
Warez requests are not allowed but if you need help with real producer you can ask in the forums.
