TipicMe and VNC Setup Qs
3 replies · 2,425 views · Started 05 June 2003
Hi, am having problems getting these two apps working. Have searched the forum but not good.
TipicMe: [list]* uses Internet GPRS and not WAP GPRS?
* have checked username and password & don't include @tipic.com in username
* using GPRS it stays at 0% then says problem with WAP
* using cradle, gets to 80% then just hangs[/list:u]VNC:[list]* Host can be a URL?? or only IP address?
* Screen is VNC display number? or port?
* when I try VNC just waits a while and then closes[/list:u]Any ideas?
Could be causes by GPRS netowork is too busy, net traffic congested or TipicMe server is too busy.
I have such problem before. Just try to connect it again perhaps later part of your day.
OR
is your current TipicMe version is the latest?
Will keep trying at different times during the day. I did just now redownload TipicME and reinstall it. Still no luck, but thanks for the suggestion.
Lantana
You're right, it does NOT work. The symptoms are those described by you.
WHO WANTS TO BUY A CHEAP P800?
:evil: :x :roll: :agrue: :agrue: :black:
