hi guys, im just a newbie here in the forum... can anyone please help me to resolve this issue? i have installed the "phonelock" software on my 3650 and while im configuring my phone, the alarm sound and states "Phone is locked" 😮 !! i know the password and it has been asked but the warning sign overlapsed the password screen so i cant enter the password!!!
is there any good samaritan who can help me on this issue please?!?!?! :cry:
phone locked while configuring the "Phonelock software&
Not seen with this product myself - but if you hold down the pencil key whilst switching on it boots the phone into 'safe mode' without running any installed apps.
May get you into the phone again where you can then uninstall it and reinstall and start over..
Best
Will
hi will , thanks for your prompt reply .. sorry.. the software name is "phonesecure" not the one i mentioned before. i got the software thru this link http://www.aijae.com/main/index.php but i can't access the site today.. and i dun knw y?!
i tried to press the pencil key .. unfortunately it didnt work..
need help badly! i can't use my phone!!
sad guest
According to the WildPalm Website you should be able to SMS to your phone, with another phone, and SMS the command UNLOCK along with your password.
Maybe this will work.
thanks mate.. actually im still configuring the phone and havent entered the phone no. yet... when it suddenly locked!! so how can i send my password?! :cry:
oh my .. im freaking out!!
Looks interesting to buy the appl.
I think it's a must to install into every phones when we buy it from the vendor, isn't?
Your probably best to speak to wildpalm direct - www.wildpalm.co.uk they make this software.
It's not 'cracked' is it?
I'm using this software, to unlock.. Just simply send an SMS from any phone to the phone that was locked...
The SMS syntax is...
::unlock your-password
hi mate.. tnx for the info ..
ive tried to send an sms to my phone ::unlock pas, but he sent incorrect password backed to me!!
is this case sensitive? my pass is numeric and starts with # 0.
is there any chance to unlock my phone??
thanks a lot for your help!
Yes, its case sensitive.
Make sure you send the password you set.
Else, i guess no ways to unlock the software.
Do you still have your warranty? If have.. i suggest you to bring your phone to Nokia Service Centre to reload the firmware.. :P
:angel: 😃 😉 😃
my phone was fixed!! i believe this software has a bug.. that cause my phone to be locked!! i emailed the manufacturer of the software and they sent me the .sis file that would fix and disabled the phonesecure... i don't think nokia can help to unlock this software as they are not the manufacturer of it... and it could not be covered by the warranty as that software is not included in the package.. but anyway im very happy that my issue was resolved!!
as a lesson don't install software that may be harmful to our phone!!
thanks guys for assisting me on this matter!! more power to you all!! 😉
Hey guest what is that .sis they sent you becuase i have a similar problem and i can't get my 7650 to work. Please help because i don't really want to take my phone to Nokia.
hi mate... i emailed wildpalm regarding my problem and they sent me the phonesecurefix.sis and the instruction to install it.
i'm also afraid to send it to nokia coz as far as i know they cannot fix it no matter what!! anyway ill upload the .sis ... kindly wait for my post ...
just don't worry your phone will be fix soon!!! =)
just don't worry your phone will be fix soon!!! 😉 😃
Please find attached a fix for the problems that you are having with PhoneSecure. The fix can be applied as follows:
1.While the phone is on, connect to the phone from a PC via Bluetooth.
2.Use the Nokia PC Suite to install PhoneSecureFix.sis.
3.Select ‘Replace’ when the software asks if you wish to replace PhoneSecure.
4.Select ‘Skip’ when the software displays a message that there is a problem with the installation - this is because PhoneSecure is still running.
5.When installation is complete, remove the battery from the phone.
On restarting the phone, PhoneSecure will no longer be enabled.
goodluck!!!
