Has anyone played Scrabble using GoBoy?
If so, when you use the Jog Dial to move up and down to select squares does it just keep going up and up and up until you press another direction?
Mine does, wondered if it was a bug with my phone, GoBoy, or Scrabble?
No other apps do this on my phone.
Scrabble on GoBoy
it's goboy, it does this with all games. try using the stylus to move up, down, left, and right by touching the various areas on the screen.
OK, thanks.
I prefer with games like Scrabble to just use the jog dial / button controls though and leave the stylus in place.
Any chance of fixing this? (whoever did GoBoy?)
Is this Scrabble on a P800 or some other gadget? Would certainly love to play Scrabble on the P800. Where does one get the game from?
Regards
You can play Scrabble on the P800 using the GoBoy GameBoy Colour emulator. You'll find the Scrabble ROMs somewhere on the Internet if you search.
You can play Monopoly too!!!
I am off to invest in Park Lane and Mayfair. Hopefully I can see the value-added on the P800 screen without the dices getting in the way. What about Cluedo?
Regards
