bluetooth->pc proxy->internet
1 replies · 1,126 views · Started 05 June 2003
Hello..
I want to get my email onto my phone(bt) using the pc as a "proxy" connected to the 'net.
can somebody tell me the steps or provide me with a link.
thanks
c
Do a search... there are lots of threads concerning that...
basically all you have to do is connect the bluetooth serial port and you should be in the go, right after you creat a specific access point for that kind of connection... the exact instructions are easy to come by here in AAS... just search...
