I found this out by accident while using FileManager:
I have always been frustrated that RemoteP800 doesn't start automatically as I seem to reboot fairly often and when I put the phone in the cradle and RemoteP800 doesn't work it is a right pain to manually start it again!!
Create a text file called 'WHATEVER.lnk' and place it in the folder C:\system\Startup. Possibly, this folder was only created when I installed HandyDay as I got the idea from Day.lnk (the only file in that folder). The text simply contains the filepath of the app you want to start, in my case, \System\Apps\RemoteP800\RemoteP800.app
I did exactly what you said but it didn't work 😞
This does work actually, I did it to get tracker autostarting. You just have to make sure you spell the name correctly! 😮ops: :roll:
(I mis-typed the name at first...)
And of course it has to be on the right disk - i.e. D:\System\startup if the target file is on the D: drive
Works fine.
u need handyday for this to work.
Is it true that without handyday this won't work? Muppet did you get it to work without handyday?
[quote="marcnyc"]Is it true that without handyday this won't work? Muppet did you get it to work without handyday?[/quote]
Yup, that's true. You need Handy Day for this..
Interesting...
Yes, I do have Handy Day installed (who hasn't?), but not running or autostarting. I may uninstall it just to see what happens.
On the face of it, unless Handy Day's installation modifies the UIQ system, then this would seem to be a funtion of the OS, not application specific. It's a long time since I've had to arse-about with boot scripts (Mac User..) so I'll have a few tests when I get round to it.
Please post your findings. I wanna find out...
I have try and double check it's file name. Everything was correct but still fail to autostart when bootup.
Works fine.
guys ... ther's another way which I find more usefull to start applications with, it's using miniGPS 😊
anc the best thing is that u can set it up to start the application whenever you get near your PC, so no need to start Remote P800 all the time when u restart, but it only starts when you get near your PC of even put your P800 on it's cradle 😮
cuz the way miniGPS works is that it detects your position to the GSM network, which is unique in every location u stay in.
it works fine with me, and I got it to start Remote P800 whenever I put the phone on the cradle, and it saves battery cuz u won't have all your application On when u don't want them
it's realy cool 😃
Iam working on the same task ie autolaunching or autostarting the application at the mobile startup. can u be please g ive the code in brief if possible.
krishna
can u give me the code for autostarting any application at the startup.
www.hw925shop.com is a professional Tiffany jewelry supplier for 3 years and won the good reputation on this line. The products of us are the best quality in china and the lowest price(not cheap bootleg), including the necklace ,cuff , ring ,earring . as 1837 style , round / heart tag style , Atlas style , Titanium style and so on . Pleasure more EBAY resellers join our company and enjoy our service. Since we are mate wholesaler and dropshipping servicer who can help you feel confidence to set up a steady business.To be exactly, you may have all kinds of questions from beginning If you're looking for a good source of wholesale Tiffany for your retail operation, online store or auction business, www.hw925shop.com is your one-stop shop for wholesale .hope you will get more surprise items on our website .
Wecome to our website: www.hw925shop.com
Email: [email][email protected][/email]
MSN: [email][email protected][/email]
