HELP my p800 stuck up!!!
7 replies · 1,650 views · Started 06 June 2003
to anybody out there who has an expertise in se p800 im begging you guys to help me: it all started when i installed the booster pack of appforge on my fon. don't know what version it was neither the version of my fons os. i installed it coz appforge had a press release that they would be partners with SE in develponing programs for the p800. still i think installing non-SE programs would void me of my warranty. when i installed it, it gave me a warning to install at my OWN RISK! should have followed that warning. i looked at the details and said that the program was not digitally encrypted. i proceeded anyways and all was going smoothly. but before the booster was completely installed an installation error message appeared onscreen saying that connection hads been lost but the device was still on its hub. my heart skipped a beat and i said S***+ don't tell me. i quicly checked on my fon if it had any effect. lo and behold it had, the os started hanging up. it had a lag time that wasn't there before when i opened applications like the cam or internet browser. after a while it started to normalize again. the lag started to disappear and i had a sigh of relief. i turned the power off to see if it had any effect on start-up (was that wrong?) and my worst nightmare waa upon me, IT HAD but not at once. the lag returned and now i cant even open the applications at all save for viewing messages. again i turned the power off hoping maybe that it was all a bad dream and that when i turn it on it would all be okey. but that was the last time i ever saw the interface screen of my p800. now all that's left is the welcome screensaver that you see when you open the fon and its stuck up there. i guess turning the device off made matters worse in my opinion. all of this happened just last night. i havent had it checked yet but i plan to later. my question is has any1 of you had any similar experience with appforge mobileVB booster installation and does my fon still have hope of being operational again? worst case scenario? please tell me something good and i promise to be contented with putting sounds, videos and music in my fon again. sob sob : ( It saddens me when i saw that there are only a few posts on the mobile VB thread, i still hoping though. dont even know if i posted this in the right thread.
Well first of all, as soon as I read appforge, I stopped reading the rest of you post. Uninstall it righ away, if you have, then try to restore you phone to an earlier time, thats if you made a backup before installing, always remember to do this before installing any new application.
If non of the above works, you will have to reformat you phones drive C.
Appforge strikes back again! Shayt!
[quote="Muzikfreakah"]Well first of all, as soon as I read appforge, I stopped reading the rest of you post. Uninstall it righ away, if you have, then try to restore you phone to an earlier time, thats if you made a backup before installing, always remember to do this before installing any new application.
Appforge strikes back again! Shayt![/quote]
the problem is that the fon is stuck on the screensaver...
i can't do anything at all...
when i poke it with my stylus it just makes the sounds...
[quote="Anonymous"] i turned the power off to see if it had any effect on start-up (was that wrong?) [/quote]
Very much so I'm afraid. The only possible solution now is to remove the battery for a while, and then reinsert it and power the device on, hoping that you will get the "disk corrupted, the device will be formatted" message. In which case your P800 will be fine again, but you will lose all your settings and installs etc. Hopefully you've been smart enough to have a recent backup at hand...
If you still get no response, you'll have to get the firmware flashed, or the device replaced.
Hope everything works out ok..
well i can handle the firmware flashed thing...
i hope it can be done and i don't care if all previuosly stored info on my fon be erased just as long as it works again! ty
