hi, this might be discussed previously, sorry in advance.
just asking if anyone knows the fastest (smartest) way to sync or copy 9210 contacts database to 7650. TIA.
You can synchronize it with, e.g. Outlook, but you won't transfer all details and fields this way.
You can send single business cards, but it is the slowest way.
You can use Contacts Manager for N9210 to export data and Contacts Manager for N7650 to import data (version with import will be released at the end of this week). Then you will transfer really all, but these apps are not free...
Option one: Use 9210's PC Suite to sync to Outlook, then 7650's PC Suite to sync from Outlook.
Option two: Use 7650's PC Suite's Data Import feature (if it happens to work with a 9210; I don't know as I don't have a 9210).
[quote="N/A"]Option one: Use 9210's PC Suite to sync to Outlook, then 7650's PC Suite to sync from Outlook..[/quote]
Then you'll never transfer all data due to the Outlook's contact card structure limitations.
[quote="N/A"]Option two: Use 7650's PC Suite's Data Import feature (if it happens to work with a 9210; I don't know as I don't have a 9210).[/quote]
Not included.
thanks Petr for the advice. wil check on Contacts Manager for 9210 and 7650.
:bday:
[quote="whiplash"]thanks Petr for the advice. wil check on Contacts Manager for 9210 and 7650.
:bday:[/quote]
Since now the Contacts Manager for N7650/3650 is also available with import function (1.0 Beta), check
http://www.agora.cz/agora/agora.nsf/0/EEFD708566D50DEAC1256CEE005AAF27
Great! One problem less to care about!!... 😊
Any app to save MESSAGES in a COMPREHENSIVE format (I mean, no plain TXT ala MessageSaver).???
