hey i got a nokia 3650, and also bluetooth usb dongles (bluegear)
basically i wanna connect my fone 2 my computer.lol sounds silly but i seem to have tried everything...and have obviously failed😞
i have installed pc suite (from the nokia cd-rom) i activate the bluetooth on my fone. but still cant seem to connect.
the problem i tink is the mRouter.it dont seem 2 find a USB dongle. It keeps looking under infrared and COM ports.argh!!!
is there any other good software??? or if ders a way wid pc suite dat b gr8.
PLZ HELP
thanks in advance
marky
Do a search mate.
Loads and loads and loads and loads of info on this subject...
will.
search...where bout.i cant seem 2 find no bluetooth device via the pc suite.it wont let me go past the first screen.keeps sayin conect your 2 cable or cancel. im havent got no cable.
I meant do a search on the forum! 😉
There are loads of threads about this subject with loads of info, I'm sure you can get your bluetooth working 😊
Here's a couple of threads to get you going, have a read of these 😊
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=8823
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?t=3075
Best
Will.
hi marky
please use the search funktion.
cya amigappc
hey guys that was gr8...cheers😊
da links were useful😊
marky mark
